Error: Insert drum cartridge
  • xmen8
    • Mar 2023
    • 9
    #16
    Re: Error: Insert drum cartridge
    It is easier to create a boot USB pen using the SST then upload the firmware using that (no need to a crossover cable etc)
    I have the SST v4.75 Ep. However, in the tool I can not select firmware that fits the IR C2380 and create a USB stick.
    • copier tech
      • 8144
      #17
      You need to register the firmware into the SST in order to create a USB boot pen.
      • Canuck
        Tech Specialist
        • 1713
        #18
        If itb assembly is old, it will do this on these models. Do the firmware first.
