Canon imagePROGRAF iPF785 - Cyan running out of ink during printing?
  • Vood
    • Sep 2023
    • 1
    Greetings,
    I've got a bit of an issue with a troublesome iPF785 and could use some help.
    It started with an issue of blank lines when printing cyan.
    A nozzle check reveals two straight blank breaks in the grid, with maybe a slight fade in other areas.
    However, after a Head cleaning the nozzle check is fine but after using cyan for a while it will run out of cyan
    - I've replaced the printhead with a brand new one.
    - Exchanged the inks to genuine canon as they were LPL.
    - Cleaned the purge caps.
    - Cleaned the Timing Strip (but maybe not well enough, will clean again next time)
    It appeared to me as though the printhead was not receiving enough ink. I've given a go with a syringe to push ink through and it doesn't appear to be blocked or leaking.
    The only thing I can really think of is that ink is just not being pushed through.
    Is this a good point at which to replace the Ink Supply Unit (L) (QM4-2875-000)? Or is there some other part I should check first?
    I'm unfamiliar with ink printers as I normally service laser printers, so any advice is welcome.
    I've attached pictures of the nozzle check before and after head cleaning. Aswell as a large poster print which demonstrates the printhead running out of cyan.
    Many thanks,
    Vood
  • GIUBOSS
    • 1381
    Re: Canon imagePROGRAF iPF785 - Cyan running out of ink during printing?
    the firmware is updated?
