Canon 8205 arızası
  • Erhanmatbaacı
    • Dec 2023
    • 2
    Canon 8205 arızası
    • 37360
    Re: Canon 8205 arızası
    If you want help, then post your problem in the correct forum.https://www.copytechnet.com/forums/canon/
    • ADV COPIER
      Pemain
      • Nov 2022
      • 249
      Title : Fixing Power Supply error
      Detection description :
      The detected power voltage differs from the voltage of the port in the IH Power Supply.
      Remedy :
      1. Check the connection between the Main Driver PCB (PCB2) and the Fixing Power Supply PCB (PCB10).
      2. Replace the Fixing Power Supply PCB with the one for the correct location (voltage).
      3. Replace the DC Controller PCB (PCB1).
      Let's Drink our Coffee
      WhatsApp +62895325228383
      • Erhanmatbaacı
        • Dec 2023
        • 2
        Remedy :
        • Kornelia
          • Dec 2023
          • 7
          Remedy :
          Thanks for solving the problem
          • igorbirokip
            • 24
            https://www.copytechnet.com/forums/c...oogle_vignette
            Just see
