canon ir105
  • docpc2
    canon ir105
    no error codes, never comes to ready, no fuser lamps, have no idea what to look for HELP!!!!!!!!!0
  • SCREWTAPE
    No lamps!!
    Go to into service mode check IO mode and check DC-CON P005 bit 14 it should be a 1 with the release handle in the up position. The first thing to check is to see if there is any paper stuck in the connector of unit 1. use a flash light and look good.
    • kwazimoto
      • Jan 2007
      • 199
      check the connectors for unit number one and number two.. the other thing to check is the front door interlocks...along with the sensor in the handle asm. that screwtape talked about...
