canon ir2800 dark prints
  • nick_schmidt
    • Jun 2009
    • 31
    Hello all
    I've got an canon imagerunner 2800
    its makes dark copies in the morning only
    fax and network prints come out fine
    just copies are dark
    any ideas????
    please help
  • pengtech
    • 41
    Check your scanning lamp. Is it light up during copying?
    • SCREWTAPE
      Yep check the lamp also clean the optics and try doing a CCD adjust.
      If you are unable to perform a CCD adjust, then you might have bad lamp or a bad CCD. Things you will notice if you have a bad lamp, it can flicker or it won't turn on.
      • nick_schmidt
        • Jun 2009
        • 31
        thanks
        thanks all
        going to customer
        going to check the scanning lamp
        and ccd test
        • MrB
          • Nov 2009
          • 147
          When you say this only happens in the morning
          Is the customer turning the machine of during the night
          Is the energy mode turned on/off
          Maybe something worth looking it, might be worth turning sleep mode off
          • davidj7
            • 1107
            how does prints come out in the mornings?
            • Tim C
              • 167
              Try giving it a cup of coffee...It helps me in the morning.. Check the scanning Mirror to be sure it was not knock out of place. I had one of my tech's do this and cause a problem...Scan lamp will do this also
