iR C3220 full auto gradation adjustment problem
  • SCREWTAPE
    East Coast Imaging
    • 3396
    If you performed a CCD adjust and it did not fail with a NG!, then your CCD is ok.
    If your having registration problems with the copier that can't perform the auto gradation,
    Then that would be the problem. If your PG6 is not uniform perfectly then that's going to be a issue.
    I would suggest to attend to the registration issue first.
      • 16083
      SCREWTAPE/ do u think he checked to see if lamp or scanner is moving ???
      • SCREWTAPE
        East Coast Imaging
        • 3396
        • sgcopiertech
          #19
          Originally posted by anothertech
          Got this from Canon Navi,
          Solution :
          In this instance after the Reader controller and the IF board had been replaced and the problem still existed replacing the ribbon cable (FH2-6983-000) that connects the two boards fixed the problem.
          I will keep you posted, thanks for the suggestions
          Originally posted by teckat
          here are two stupid questions ??
          did u look to see if your lamp is staying on through the test scan ?
          is the scanner moving forward ??
          do u have an image pass on this machine/
          if so have u tried a calibration from Firey/w Kodak Grey scale ?
          yes lamp is ok and moving
          the machine doesn't have image pass.
          just to add why would replace the CCD/ if you can print off the glass with no errors and no CQ issues ?
          well, I've got experienced on this machine where as when checking the laser it says ok
          but ends up being the the culprit, so I was just wondering if it's the same case with the
          CCD or Reader PCB.
          PG6 alignment is ok
          (problem machine) auto gradation test print alignment compared with (ok machine) auto gradation test print is also ok.
          thanks again!
          • SCREWTAPE
            East Coast Imaging
            • 3396
            #20
            Your reader controller pcb maintains your ADJ-XY values.
            If your CCD adjust did not fail, I would have to say at this point..
            Try replacing the reader controller PCB. Keep us posted.
              • 16083
              #21
              on your PG10 do u have a non image area on all four sides
              have u tried to calibrate with either a 11x17 / & Ltr-r size
                • 16083
                #22
                CCD or Reader PCB.
                PG6 alignment is ok
                thanks again!
                also what about that copyboard cover switch/sensor/that reads paper size for prints and auto gradation/ sends to CCD for original detection position
                if u make copies off the glass/and did a CCD adjust/ your Reader n' CCD are ok
                • smiley
                  • Aug 2008
                  • 615
                  #23
                  on pg 10 you can also see if there is a displacemant,if there are colors that overlap the other color or if there is a blank area between any of those color.and you can see it at the 1st testprint of the auto grad.each color should have aligned equaly at the leading edge.
                  there is no glory without sacrifice
                  • sgcopiertech
                    #24
                    quick update:
                    PG10 print is ok no displacement
                    do you mean, the original size sensor?
                    paper size detection ok.
                    I changed the reader controller PCB
                    but still same problem.
                    I can't concentrate on the machine too much.
                    still need to do a lot of orders.
                    I'll put it one side first but will still post the solution (hoping can still solve)
                    once I'm free.
                    thanks!
