change drum in irc2880...
  • maurimx
    • 116
    Where are the drums in the irc2880 and how do I change them ??
    I cant seem to find how to start or get to them..
    I had a irc3220i which was pretty straight forward...
    thanks for the help again guys !
  • Ikon Princess
    • 126
    go to youtube and do a search for "3380 copier" and select install
    • maurimx
      • 116
      thanks ! lets see how that goes
      • teckat
        • 16083
        hey that is a great video/ wonder if Canon has seen that ???
        • maurimx
          • 116
          excellent video.. helped out perfectly ! thanks ikon
          • teckat
            • 16083
            Do not replace drum units with new ones unnecessarily, in order to check function operations during service, etc. The device blows the drum fuse as soon as it detects a new drum unit and resets the drum life counter to 0. Even if the old drum is replaced immediately, the drum life counter will increment as a new drum unit.
            In Service Mode COPIER>FUNCTION>INSTALL >AINR-OFF invalidates drum initialization that is performed when a new drum unit is installed. Also, the fuse is not blown, as it would usually be after drum initialization is complete.
            This mode would be used to replace a drum unit temporarily in order to check image quality, for example trying to trace the cause of the problem.
            0: Initialization carried out for new unit. Fuse blown (Default)
            1.: No initialization for new unit. Fuse not blown.
            Further, this service mode should be set to [1] only when necessary for service. After the service is complete the setting must always be returned to [0].
            • Ikon Princess
              • 126
              You are welcome. My web-surfing junk is your treasure.
