Help with canon clc 5100 Problems printing no errors code given
  • sas386
    • Jun 2025
    Every 3rd sheet about is out of register vertically up to an inch. No error codes tried resetting everything but didnt help at all. Do you have any idea what might be causing it to print this way?
    It only does it when i print from a computer through the network if i print off the glass or use as test page it prints fine. Any ideas would be apperciated.
    • 16083
    check settings below
    Go into Service Mode *28*
    FUNCTION>INSTALL>(2/4) IMG-REG 0---------- 1
    OPTION>P-OPT>AUTO-REG 0---------- 1
    OPTION>P-OPT>RT-PWR 0----------- 1
    OPTION>P-OPT>PSTCL-SW 0---------1
    Execute FUNC>IMG>AUTO-ADJ
    post some pics !!!!
    • sas386
      thanks ill give that a shot im not at the office at the moment but when i get back ill take some pics
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Are the test prints coming from service mode or from the fiery?
        Can you tell if it happens before the Fiery or after?
        If it is just coming from their computer try deleting the printer and reinstall with the latest driver from Canon U.S.A
