Canon IR 2020i
  • tcypy1961
    • 773
    Canon IR 2020i
    customer pulled bottom drawer out while primary feed tires(half moon) were in the down position. the shaft was busted not sure what all has been damaged don't have manual on this copier. Checked precision roller they only have the rollers. Will these parts need to come from Canon???
    Is the bottom tray an accessory or part of copier???
    Thanks!!!
    • 16083
    Thanks!!!
    Precision Roller has the shaft =link below
    http://www.precisionroller.com/fb6-1..._pn_32802.html
    CANON FB6-1631-030 SHAFT - Pickup Roller Shaft - Genuine Canon Part
    if u have three cassette draws, they are part of the Cassette Feeding Module-J1
    if four trays>
    the two bottom trays are part of the Cassette Feeding Module-K1
    , add on option
    FB6-1631-030 =SHAFT, for=PICK-UP ROLLER
    both units use same shaft
    • mjarbar
      Hello,
      Assuming the bottom tray you refer to is one of the standard 2 trays the machine comes with and not as Teckat says an additional cassette unit, they are a part of the machine. However Canon in their infinite wisdom (NOT!) have decided that you cannot buy the whole unit as one piece.
      Can you let us know what has been dammaged on the cassette and we may be able to find the correct part code for you, but please be aware that due to the nature of these parts you may have to end u getting them from Canon themselves.
      Sorry couldn't be of more help at the moment but all the best.
        • 16083
        Originally posted by mjarbar
        Hello,
        Precision Roller also has it>
        Buy Canon toner, Canon supplies and Canon parts at Precision Roller and get free shipping on qualifying orders!
        u can order a entire CASSETTE=FM2-3313-000 /from parts dept.
        Cassette Feeding Module-J1/J2/K1/K2/L1
        FIGURE NO. KEY NO. PART NUMBER RANK QTY SALES QTY DESCRIPTION DESCRIPTION(JP) REMARKS
        none FM2-3313-000 1 CASSETTE
        1 FB4-5814-000 1 PLATE, SIZE, REAR
        2 FB6-1640-000 1 LEVER, PAPER SIZE
        3 FB6-1644-000 1 LOCK, PAPER LIFTING PLATE
        4 FB6-2000-000 2 SPRING, COMPRESSION
        5 FC6-4337-000 1 COVER, CASSETTE
        6 FC6-4361-000 1 PLATE, SIZE INDICATOR
        7 FM2-3325-000 1 PAPER SIDE GUIDE (F) UNIT
        8 FB4-5809-020 1 LEVER, LOCK
        9 FB4-5813-020 1 PLATE, HOLD-DOWN TAB
        10 FB4-5810-000 1 PLATE, PAPER CONTACT
        11 FB6-1646-000 1 SPRING, LEAF
        12 FB6-1649-000 1 SPRING, LEAF
        13 FM2-3326-000 1 PAPER SIDE GUIDE (R) UNIT
        14 FB4-5808-020 1 PLATE, HOLD-DOWN TAB
        15 FB4-5824-000 1 LABEL, LIMIT
        16 FS6-2917-000 1 SPRING, TENSION
        17 FS7-0207-000 1 GEAR, 20T
        18 FB6-1650-000 2 SHEET SEPARATION
        19 FU5-8588-000 1 LABEL,SIDE LOCK
        20 FU5-8587-000 1 SHEET, PAPER SUPPLY
        501 XB4-7401-009 2 SCREW, TAPPING, PAN HEAD
        *****make sure u have no damage to the paper feed units/ as in the sensor arms & or missing springs
        also check what caused the rollers to stop out of position !!!!!
        • mjarbar
          Many thanks Tekcat, I have made a note of the Cassette part number as the parts catalogue I had for these models didn't have them in, I have also added to your Rep for the assist.
          Thanks.
          • mjarbar
            the feed assy with the half moon pulleys is hanging down on front side. so i guess whatever holds it in place on front side of copier.
            Thanks!!!
            The rollers and shaft connect into the main frame of the paper feed assy via a block and bushing. If you are just missing these the part numbers are:
            FC6-4351-000 1 SHAFT, ROLLER
            FS1-1205-000 1 BUSHING
            If the frame itself is dammaged then you will have to replace the whole thing:
            FM2-3320-000 1 PAPER PICK-UP ASSEMBLY.
            Hope this helps.
