5151 : Missing magenta only when use/chose heavy paper.
  • teckat
    • 16083
    #16
    Originally posted by Van Steal
    Hi tecket
    I had a fade out issue on a run that looked like transfer fault..I know your dead set on it being a sepping motor and you may well be right but I'm just reporting a fault that I had..
    Sorry, I did not mean u had a displacement issue/ usually when u replace a Laser it is for some type of image distortion issue & not a Fade out on certain paper types
    reason I quoted the stepping motor fix for Heavy Paper is because I had already experienced this at a few accounts
    if poster will try the Manual Feed test posted above, it could point them in the right direction
    • jettamand
      • Sep 2010
      • 30
      #17
      Once again for you.... :-)
      Only magenta drop if I CHOSE HEAVY PAPER......NO PROBLEM when printing/copying on HEAVY MEDIA as PLAIN PAPER !!
      AND YES, after 20 years as technican i now how a stepping motor operate ;-)
      • Gamut
        • Jul 2008
        • 216
        #18
        teckat has given you the correct solution for that problem, I have replaced drum drive motors on 2 machines for this exact problem. OK on 80gsm paper no go on heavy. REPLACE motor.
        • teckat
          • 16083
          #19
          Have 27yrs. Exp. / 24 yrs. on Canon Color products
          I know this series model blindfold/ I had 22 of them at one in house Acct /
          You just proved the point !!! Simple Fix= Replace the Motor
          • Fer
            • Nov 2009
            • 267
            #20
            Replacing the drum motor isn;t expensive or very much work, so worth the try i guess. Personaly i think that if the HVT is already replaced, the problem is caused by the developper. Replace the M developper motor or complete drum drive assy.
            btw. Suggesting the laser isn't that odd, i had a laser fry my drums within 1 minute of "adjusting gradation please wait"
            • teckat
              • 16083
              #21
              if M Laser was bad= all Magenta on all paper types would be effected -/ Laser issues are easy to determine in this model u just swap them- to see if issue follows
              if M Developer Mtr was bad it would also effect Magenta on plain paper
              poster has issue only on Heavy Paper or when Heavy is selected for Plain Paper/
              All that points to the Drum Drive Mtr.
              • Fer
                • Nov 2009
                • 267
                #22
                The idea of replacing a part where at a certain point, u can see trough the machine, is not very comfortable.
                • teckat
                  • 16083
                  #23
                  if a tech is looking for comfort on this job, they should look for a job in Sleepy's
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    #24
                    [ATTACH=CONFIG]6772[/ATTACH]
                    Ha,Ha,Ha
                    Good one...
                    • Canuck
                      Tech Specialist
                      • 1713
                      #25
                      Is this thing fixed yet? Wow what a thread!! I would have cleared the ram and reloaded firmware to start. Everybody says change the drum drive. DO IT. Usually bad drum drive gives E-0012 though...
                      • ReproKev
                        • 273
                        #26
                        Ditto on the Drum drive assm. I had the same problem a few months ago and was told the same fix from these guys. I replaced it and all was good. Good advice.
                        • Van Steal
                          • 177
                          #27
                          tectat gave good advice(as he always does) with the drum drive but he's thinking else where
                          • teckat
                            • 16083
                            #28
                            E012-
                            0001 Drum ITB motor fails to run.
                            0002 Drum ITB motor runs but then stops running.
                            0003 When the drum ITB motor fails to stop
                            this is not what the poster is experiencing
                            Clear Ram or re-loading Firmware will not fix a stepping motor issue for Heavy Paper selection/
                            • Canuck
                              Tech Specialist
                              • 1713
                              #29
                              E012-
                              sure
                              • teckat
                                • 16083
                                #30
                                sure
