Backing up ir5000
  • andalasgt
    • Oct 2010
    • 49
    [Misc] Backing up ir5000
    Hello,
    i have ir5000. how to backup the firmware and system?..
    My machine now it's OK, but in order to have preparation before it's trouble.
    thank's
  • SCREWTAPE
    East Coast Imaging
    • 3396
    You need SST and firmware for this kind preparation. Backing up software will not save you.
    • andalasgt
      • Oct 2010
      • 49
      thank for replay.
      can I backup firmware n system from copier to laptop? I already have SST4.23E...
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Originally posted by andalasgt
        thank for replay.
        SST is used to load fresh software from your laptop to the copier, it does not "back up" software from the copier to the laptop. Some people speak of cloning hard drives, but that is not a practice that I endorse. It would be better to locate the System Software for your model.
        • badboys
          • Oct 2010
          • 69
          Hello,
          thank's
          There is 2 options:
          1.The correct way = SST & Firmware
          2.The easiest way = Clone the virgin/original/working HDD.....but Beware!!! in some country you are not allowed to do so due to security reasons.
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1247
            If your hard drive is ok - then why back it up. When it fails someday it's a simple matter to have a new one installed by a Canon tech and loaded with the most recent version of the system software. Are you having problems right now that you think are related to the hard drive? Is that the reason for your inquiry?
            • andalasgt
              • Oct 2010
              • 49
              Thank's for the replies. Now I've understood, That SST is used to load fresh software from laptop to the copier, it does not "back up" software from the copier to the laptop (as Mr. mrfixit51 said).
              Your answers are very helpful.
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Glad you understand. Now you gotta get hands dirty.
                • teckat
                  • 16092
                  • andalasgt
                    • Oct 2010
                    • 49
                    Once again, thank you. This site is very helpful.
