iPRC7000VP E020-0281
  • pga
    • Jul 2009
    • 67
    [Error Code] iPRC7000VP E020-0281
    Dear All,
    Any ideas on this error code? I was changed Drum unit,developing unit,LASER, ITB Drive motor.
    The P-B-P-M at level 2 always show "0". What part will causing it?
    Besides, it also paper jam 0110. Sometime the printout will be registration out. No leading edge.
  • teckat
    • 16092
    Originally posted by pga
    Dear All,
    E020
    E020-0x81
    Error Description: Lower limit error in light intensity on drum base (reflecting light intensity from
    the drum surface)
    * COPIER > Display > DENS > P-B-P-Y/M/C/K is less than 150.
    Cause of occurrence (Highly possible): Soil on the ATR sensor [*1]
    Cause of occurrence (Low possible): Faulty pressure for developing assembly
    Broken wire of ATR sensor
    Damaged ATR sensor
    Malfunction of ATR patch detection shutter
    Check the P-B-P-Y/M/C/K readings under COPIER > DISPLAY > DENS. Readings are typically between 300 - 650.
    Check or Replace Drum patch Sensor PS117= shown in red square
    • teckat
      • 16092
      imagePRESS 6000 / 6000VP / 7000VP Image Registration is Off
      Check PS110 lead edge patch registration sensor. If you disconnect this sensor and the image registration comes back into specification, suspect a faulty PS110 lead edge patch sensor. When you disconnect this sensor, the ITOP signal from the yellow laser unit will be automatically used.
      Also, check to see that there is a good gloss on the ITB belt for better reflectivity of the PS110 patch sensor.
      NOTE* For the ITOP signal to be automatically used you must have version 71.02 installed.
      • teckat
        • 16092
        imagePRESS C6000 / C6000VP / C7000VP
        Varying lead to trail registration on the imagePRESS C7000VP Series.
        The lead to trail registration shifts during a multiple print run.
        The ITB home position is determined by detecting the reflecting surface on the edge of the ITB with the ITB HP lower sensor (PS101) or the ITB upper sensor (PS102) as shown in the diagram below.
        This is a white reflecting surface that resides on the rear underneath the ITB belt which obviously can get dirty in time. If this reflective surface is dirty, it can miscalculate the ITB home position and therefore affect the lead edge registration. Clean this reflective surface and the ITB home position sensor mentioned here.
        • pga
          • Jul 2009
          • 67
          when i replaced a new developing unit,the drum patch sensor is attached with it. The D-kit and P-kit, i also cleaned it.
          • teckat
            • 16092
            M unit could be bad/ check other thoughts/
            are u using OEM part ?? or a Boot leg Part
            are u trained on this model/ is firmware up to date ?
            • Elizaldo
              Re: iPRC7000VP E020-0281
              I remember to solve this problem doing a DC-CON CLEAR on Copier>Function>Clear>Dc-Con and filling the values of the Service Label.
              Notice if the Density values are close, and if the Laser values on ADJUST are the same of the label.
              If the counter is large (in my case it was 1,5M), this probably will work.
              Hope I have helped.
              • teckat
                • 16092
                Hope I have helped.
                that post reply from me was back in year 2010
                • Van Steal
                  • 177
                  That has to be a record
                  • hasan5900
                    • Dec 2015
                    • 13
                    Re: iPRC7000Vp E000062-0100-05
                    iPRC7000Vp E000062-0100-05 plase hilp
                    • teckat
                      • 16092
                      E062-0x00-----------------x= 1:Y 2:M 3:C 4:Bk
                      -------0100=YELLOW__Error: initial lower temperature After the machine was activated, the temperature only increased by 0.5
                      deg C or more per minute in the condition where the drum was being stopped, before reaching the target
                      control temperature (42.5 deg C).
                      MANUAL CHECKS
                      1. Check drum heater switch (SW120) (is the drum heater switch ON when the process unit cover is attached?) -> Reattach
                      process unit cover.
                      2. Check following for faulty connection/ loose wiring ->Disconnect then reconnect connectors.
                      - Environment heater driver PCB (J4400/ 4405/ 4404/4401)
                      - Terminal mount (J7856)
                      - DC controller PCB 1-1 (J1054)
                      - Drum surface temperature sensor
                      - Process unit driver PCB (J1361/ 1378)
                      - DC controller PCB 1-2 (J1007)
                      3. Clean drum heater contacts (slip rings).
                      4. Replace environment heater driver PCB.
                      5. Replace drum heater.
                      6. Replace drum surface temperature sensor.
                      7. Replace process unit driver PCB.
                      Check your drum temps in service mode under
                      Display-Analog-DR-TMP-Y,M,C,K.
                      Remove the Yellow Drum to check the Drum Heater Contacts.
                      Make sure they are not completely missing. The heater comes installed on the drum from the factory.
                      PICTURE>EXAMPLE OF MISSING CONTACTS
                      If the Drum Heater Switch is bad, or the cover is not attached to engage the switch, the Error will be displayed.
                      Inspect and replace any blown fuses (part number VD7-2892-001) on the Environmental Drum Heater Driver PCB.
                      Inspect the wire harness of the Yellow Processing Unit /make sure it's not pinched wire under a wire tie.
                      This is the wire harness leading from the rear connector to the Process Unit Driver PCB (Y).
                      Check all connectors on the DC controllers and cut all wire ties on the AC wire harnesses and DC wire harnesses.
                      • hasan5900
                        • Dec 2015
                        • 13
                        E020
                        E020-0x81
                        the drum surface)
                        Damaged ATR sensor
                        [ATTACH=CONFIG]6792[/ATTACH]
                        Where there ATR Sensor pictures Please
                        • teckat
                          • 16092
                          The correct part number for all 4 (Y,M,C,BK) Drum Patch Sensor is FK2-3168-000
                          after replacing the Drum Patch Sensor
                          1. Enter the value on the label attached to the drum patch sensor (COPIER > ADJUST > DENS > ALF-Y/M/C/K)
                          2. Execute forcible warm-up rotation mode (COPIER > FUNCTION > MISC-P > INTR-EX)
                          • hasan5900
                            • Dec 2015
                            • 13
                            Re: iPRC7000VP E0822-1603-05 plase help plas
                            help
                            • teckat
                              • 16092
                              E0822-1603-05
                              IN MANUAL it will show Y as description = see below
                              Y=0: detection at the time of normal rotation
                              Y=1: detection at power on
                              you have a FAN ISSUE, manual has no listing for 603 location
                              what area in printer where u working before code ??????
