hi guys...i've got problem with finisher on ir 2020..it is displaying system error 540
when power on...i apreciate any solution gentlmen
thanks in advance.....
An intermittent E540 code appears during the power up sequence.
The E540 is defined as an issue with the Finisher Tray
The tray on the Finisher U2 does not move.
Check The sensors / and for 13vdc and 24vdc measured on the finisher controller PCB.
Check the Finisher Controller PCB -# 4G3-0806-000.
thanks for help mr.teckat..but there is another question please can i disable the function of the finisher while it is installed on the machine body ?..or make the machine ignore it and work without it ..is this available on this model of canon?this is temporary until we get the parts..
thank you again ....regards
how many trays do u have ?
if u have the Additional Finisher Tray-C1 , u may be able to change delivery options U Finisher has one tray, unless C-1 is added on trays.JPG
E540
what was your sub code after E540-XXXX ??
0001 Paper surface not detected
0002 Not moved within the specified time
0003 Sensor not reached within 3 seconds
0005 Encoder clock failure E540 is usually on standard tray !
E542 is used when optional U tray is installed/ same sub codes apply
E540 0001 - Standard tray shift motor or finisher controller PCB failure
- Standard tray HP sensor failure
- Standard tray clock sensor failure
- Standard tray shift motor load failure
The standard tray was moved but the
paper surface was not detected.
- Check the connector of the standard tray HP
sensor.
- Check the connector of the standard tray clock
sensor.
- Check the connector of the standard tray shift
motor.
- Replace the standard tray HP sensor.
- Replace the standard tray clock sensor.
- Replace the standard tray shift motor.
- Replace the finisher controller PCB. 0002 - Standard tray shift motor or finisher controller PCB failure
Cannot move (to the pickup position)
within the specified time.
sensor.
sensor.
motor.
- Replace the finisher controller PCB. 0003 - Standard tray shift motor or finisher controller PCB failure
The standard tray was operated, but it did
not reach the sensor within 300 ms.
sensor.
sensor.
motor.
- Replace the finisher controller PCB. 0005 - Standard tray shift motor or finisher controller PCB failure
The encoder clock signal was not
detected two or more times when the
standard tray was operated for 300 ms.
sensor.
sensor.
motor.
E542 0001 - Optional tray motor or finisher controller PCB failure
- Optional tray HP sensor failure
- Optional tray clock sensor failure
- Optional tray shift motor load failure
The optional tray was operated, but the
- Check the connector of the optional tray HP
sensor.
- Check the connector of the optional tray clock
sensor.
- Check the connector of the optional tray shift
motor.
- Replace the optional tray HP sensor.
- Replace the optional tray clock sensor.
- Replace the optional tray shift motor.
- Replace the finisher controller PCB. 0002 - Optional tray motor or finisher controller PCB failure
sensor.
sensor.
motor.
- Replace the finisher controller PCB. 0003 - Optional tray motor or finisher controller PCB failure
- The optional tray was moved upward,
but it did not reach the HP sensor within
3000 ms.
sensor.
sensor.
motor.
- Replace the finisher controller PCB. 0005 - Optional tray motor or finisher controller PCB failure
- The encoder clock signal was not
optional tray was operated for 300 ms.
sensor.
sensor.
motor.
How to enable a new finisher on the IR 2020 and how to Disable it on IPSWITCH MODE"
This should come on the set up direction for the finisher and also in the service manual for finisher or for the copier itself.
Please let us know if you know about this procedure.
Thank you!!
Finisher U1
there is no Enable or Disable for Finisher U1/ in Manual or Install instructions
it uses a Option Power Supply Kit - Q1 this kit uses two harnesses / one attached to it's pcb board >that goes to printer power supply pcb connector J16 & other loose harness from Q1 kit pcb connector J53 to connector J18 on printer power supply
remember that the Cassette Feeding Unit-Q1 uses the same Kit/
