Ir 3220 lỗi treo máy khi cắm print controler.
  • ngoclongchau
    • Apr 2011
    • 11
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    If i understand you have controler issue.Do you have any errors?
    • ngoclongchau
      • Apr 2011
      • 11
      When i connect Printer controler with Photocopy ir 3220 and set IP, then i turn off and turn on machine keyboard controler not active. (my poor English horrible), plese help me. Thank you so much.
      • zoraldinho
        • Mar 2008
        • 5015
        Are you shore about model.IRC 3220 maybe?
        • ngoclongchau
          • Apr 2011
          • 11
          I sure IRC 3220.
          • zoraldinho
            • Mar 2008
            • 5015
            Set [3] in the Copier's service mode: COPIER >
            OPTION > INT-FACE > IMG-CONT.
            - Set [1] in the Copier's service mode: COPIER >
            OPTION > BODY > CNTR-DSP.
            Checking the Operation After Making
            Settings
            Print out the test page and setup page as follows to
            check that the connection be tween the server unit and
            the host machine is correct and the serve r unit has as
            properly been set up:
            1) Connect the host machine's power cable (for power
            outlet).
            2) Power on the ColorPASS/PS-NX by pressing the
            power button on the front panel.
            3) Wait for the ColorPASS/PS-NX to reach the Idle
            screen to confirm that the ColorPASS/PS-NX is
            operating properly.
            4) Following a successful startup, shut down the
            ColorPASS/PS-NX .
            5) Connect one end of the copier interface cable to the
            ColorPASS/PS-NX and connect the other end to the
            copier.
            6) Connect one end of the Command/Status Ethernet
            Crossover cable to the lower RJ-45 port on the back of
            the ColorPASS/PS-NX and connect the other end to
            the RJ-45 port on the copier.
            7) Power on the copier and allow it to warm up.
            8) Power on the ColorPASS/PS-NX using the power
            button on the front pannel.
            9) Generate a Test page and a Configuration Page as
            follows, and check to make sure that they are
            generated normally: press the Menu button and, from
            the Functions screen, select [Print Pages]-[Test Page]
            or [Configuration].
            • ngoclongchau
              • Apr 2011
              • 11
              How to set 3? (Software error, so not press keyboard). (I am in Vietnam). Thank you very much.
              • ngoclongchau
                • Apr 2011
                • 11
                I am sorry, I described.
                When I plug the print controller in, then setting new IP then restart the printer, the printer was frozen. What's wrong with this and how to solve? (The problem occured with other printer as well).
