iR 4570 Hard disk repair
  • misseducation
    Need help here for repair the iR4570 hard disk using sst.. i already have the 4570 firm ware, but i cannot connect it to the pc, when i'm using new hard disk i connect the machine with pc, the machine won't start..
    Anyone can help me..?
    • 16083
    where did u get this HDD ?/
    U need to first format the HDD in SST
    Only one Copy of the Service Support Tool should be present on a given PC.
    is laptop IP address set to 172.16.1.101 and the fixed IP address of the machine at 172.16.1.100. And the subnet mask is 255.255.255.0 and a known working crossover cable is being used.
    remember**** if using
    The Service Support Tool v4.22Et /it may not work properly when connected to an imageRUNNER 2270/ 8570/ 9070 series with a BootROM prior to v6.36
    • misseducation
      I'm buying second hand machine, when it comes to my place the hard disk is nor working, i want to restore the hard disk using sst, i'm already have the firmware but it cannot connect, what should i do..?
      Could u help me by describe the step by step with using sst...?
        • 16083
        set up IP addresses as above
        use a crossover cable between laptop and printer
        go in download mode on printer
        open SST/ & SEE ABOVE or use Assist Mode
        • misseducation
          teckat.... Thanks alot, i will try it....
          • LAGHNOJA
            IR 4570 HDD
            I NEED Service support tool FOR IR 4570
            PLEASE SEND IT TO ME HITUJUST4U@GMAIL.COM
            • LAGHNOJA
              IR 4570 HDD
              • misseducation
                Sorry they not allowed us to give the sst firmware...
                am i right teckat..?
                  • 16083
                  it is up to the individual person if they want to provide it privately through a Personal Message.
                  • mrfixit51
                    Lead Service Technician
                    • 1975
                    In truth you need Service Support Tool AND the System Software for the 4570. Service Support Tool is just that, a tool, without the System Software, you will not be able to do much with your hard drive issues...
