what is xfer cleaning blade assy
ir 3100 colour copier
Its what cleans the transfer belt (itb). The drum unit on this model also might be causing your streaks among other things. You should call for service.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.com -
ITB Cleaning blade= scrapes off the toner remaining on the ITB.
Drum Cleaning blade (polyurethane rubber)= scrapes off and removes the toner remaining on the drum from previous transfer to the ITB.
If you have to place the ITB cleaning unit on the floor after removing it from the machine, be sure to orient it as shown (i.e., so that the releasing arm is parallel with the floor); otherwise, the waste toner inside the ITB cleaning unit can start to leak.
CLEAN.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
