Ir4570 copies upside comes very lighly????
  • beejong
    • Jul 2025
    Hi..
    One ir4570 recently i have to make copies it will comes upside very lightly..
    I have to change some parts for better results.
    That parts are..
    1.new drum and charging roller
    2.cd-rot unit toner fully cleaned with blower changed with new toner.
    3.new fuser film .
    4.laser dust glass clean with smooth cotton.
    But no result..???
    I can make prints and scan it will comes very clearly..
    But only copies are very lightly on upside only..
    no matter how many copies i done,all is upside very lightly..
    How to make changes for beeter result for as it is copy...??
  • godyng
    • Dec 2008
    • 40
    How about the laser polygon motor mirror or the developer ??
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5013
      check the version of the Reader Controller,replace Contact Image Sensor with new one.
      post a pic.
      • zoraldinho
        • Mar 2008
        • 5013
        reading material for your issue.
        ir4570-037.pdf
        ir4570-024.pdf
        • beejong
          all i already try..but the result still same..
          • zoraldinho
            • Mar 2008
            • 5013
            Yea wright!
            http://www.copytechnet.com/forums/ca...direction.html
            • V-P
              • Apr 2011
              • 679
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                If PC prints are good, and service mode test prints are good, and copies are bad, look to your scanner for the problem. Run CCD adjust...
