Canon DR-9050C Scanner Delays when imprinting
  • DazzPFR
    • Jun 2011
    • 8
    [Misc] Canon DR-9050C Scanner Delays when imprinting
    I have a user that is using a canon 9050c scanner and when you do a scan job with imprinting it scans the first few pages fine then it delays a bunch between pages. He showed me on the 9080c they have that it doesn't delay at all. He is claiming the 9050 is a newer model and there should be no delay. I tried changing the control board and it still did it. Any ideas or suggestions? Thanks.
  • teckat
    • 16083
    9050C-Y/2009
    9080C-Y/2003
    Firmware for the DR-6050C/7550C/9050C has been upgraded to version 1.13. ?????
    Check if ISIS/TWAIN driver has been upgraded from version 1.0 to version 1.2
    CapturePerfect 3.0 has been upgraded to version 3.097/In order to completely utilize this update, a previous version of CapturePerfect 3.0 MUST already be installed.
    if using the SCSI connection
    You may have to change the SCSI transfer rate in User Mode
    Note: If you change the transfer rate you need to reboot the scanner.
