I have a user that is using a canon 9050c scanner and when you do a scan job with imprinting it scans the first few pages fine then it delays a bunch between pages. He showed me on the 9080c they have that it doesn't delay at all. He is claiming the 9050 is a newer model and there should be no delay. I tried changing the control board and it still did it. Any ideas or suggestions? Thanks.
Canon DR-9050C Scanner Delays when imprinting
9050C-Y/2009
9080C-Y/2003
Firmware for the DR-6050C/7550C/9050C has been upgraded to version 1.13. ?????
Check if ISIS/TWAIN driver has been upgraded from version 1.0 to version 1.2
CapturePerfect 3.0 has been upgraded to version 3.097/In order to completely utilize this update, a previous version of CapturePerfect 3.0 MUST already be installed.
if using the SCSI connection
You may have to change the SCSI transfer rate in User Mode
Note: If you change the transfer rate you need to reboot the scanner.**Knowledge is time consuming, exhausting and costly for a trained Tech.**
