Canon CLC 3200 copy problem (see attatched sample copy)
  • goldencup
    • Nov 2008
    • 366
    Hi! I would like to seek help from you about Canon CLC 3200. I have attatched my sample copies here. The problem with the machine is that whenever I make PS Test Page, the copy is good . But whenever i make copy from the platten glass, the copy is not good . What seems to be the problem? Thank you very much...
  • Techace
    • 35
    Re: Canon CLC 3200 copy problem (see attatched sample copy)
    hi. open back cover then open the cover of main controller then take out the board on top then put again. sorry my english is not much good. i ve attached the pic too. check it out. then make auto gradiation adjustmentirc2620-contoller.jpg
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      The blue one PS test page is print and the good one is copy i believe.Do you have ADF?
      • goldencup
        • Nov 2008
        • 366
        the blue one is copy while the good one is the print from the test page under Function. I do have ADF.
        • zoraldinho
          • Mar 2008
          • 5015
          Do you have issue when you using ADF?If you have,try to clear R CON.
          • charm5496
            • 2387
            clear you RCON, clean your optics and perform a CCD adjustment.
            • goldencup
              • Nov 2008
              • 366
              Thank you for all your help I will do all the instruction that you've given to me.
