Re: canon ir2016 with "download standby" message
Please... really need help guys! I need SST and Firmware for IR2016... I'm new to Copier and a little push and help would be certainly much appreciated!!! thank you!!!
hello friends,
i've also the "donwload standby" message on my 2016. Can anybody support me with tools and hints please?
Thanks in advance.
Emailaulik80@googlemail.com
Sorry guys for repetition, Few days ago I was trying to write new Boot Rom of Canon IR2016 with SST ver3.11 but failed since the 'DOWNLOAD STANDBY' still displayed on the machine. I succeeded to write new Boot Rom four different machine of the same model with this version of SST. I dont know where i went wrong since I've followed the procedure correctly,... Any suggestions? or maybe I need new version of SST apart from the one I have which is ver3.11? ...
Best Regards!
Best Regards!
iR2016 & iR2016i use different firmware
are all models u have the same ?
what ver. of firmware do u have ?
2016/2020=v66.01.01
Main v66.01
BootROM v60.02
Language - -
PCL v71.02 [32M-OPT]
E-CNT v8.01 (Must change DC CONT PCB to upgrade)
Finisher-U1 v7.06 ---------------------------------------------------------
2016i/2020i Main v71.02.01
BootROM v60.02
Language v71.02
PCL v71.02 16M-OPT]
Finisher-U1 v7.06 When upgrading the imageRUNNER 2016i/ 2020i copier to v70.01.01 the Language, and
PCL of the copier also needs to be updated to v70.01
Points to note when upgrading from ver. 10 or earlier to ver. 60 or later:
I've encountered this kind of problem before. what i did i replaced the image processor board. the one with backup battery in it/fram counter board.
hope it helps.
