iRADC9075PRO / C9065PRO / C7065 / C7055 - All Serial Numbers Affected
Items to Note When Installing or Replacing a Transfer Cleaning Blade
Publication has been revised to detail an added procedure.
Changes can be found on pages 1, 5, 7 and 8.
see PDF>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>TP10.pdf
There are six (6) items that Canon U.S.A. Inc. would like to bring attention to when installing or replacing
the Transfer Cleaning Blade. The following briefly describes these steps:
1. Application of lubricant to the blade plate to prevent warping of the transfer cleaning blade
2. Notes when attaching / detaching the Transfer Cleaning Assembly to prevent either faulty cleaning or warping of the transfer cleaning blade.
3. Notes when replacing the Transfer Cleaning Assembly to prevent a possible fault during cleaning.
4. Notes when handling the blade plate to prevent faulty cleaning or warping of the transfer cleaning blade.
5. Points to note if either faulty cleaning or warping of the transfer cleaning blade occurs.
6. Points to note when replacing the blade plate.
