e 225-000 ir 6000
  • smiley
    • Aug 2008
    • 616
    e 225-000 ir 6000
    hi guys we already try to replace the xenon lamp the inverter pcb the rcon, the ccd assy. the dcon and harness all over the scanner unit with no luck. the lamp blinks 20 times after power on and give this error. any body in counter this before? pleased help me thanks.
    there is no glory without sacrifice
  • adhy
    • Feb 2011
    • 109
    Re: e 225-000 ir 6000
    Did you had replace the copy glass board and ribbon cable?
    • smiley
      • Aug 2008
      • 616
      yes already replace the copy glass and also the ribbon cable the one that connect the ccd assy and the rcon.
      • spectraindo
        • May 2008
        • 313
        Check the mirrors (3) maybe it is out of position, check the plastic slide pins if broken then the mirror will be out of position.
        when the CCD cannot get the image of the white stripe on the copyboard glass then you get E225.
        • charm5496
          • 2387
          are you sure you put the correct copyboard glass in with the white strip?
          We have had techs goof up and do this in the past.
          • mr.daus
            • Apr 2011
            • 98
            try to carefully check the CCD flat cable installation, check the white board glass plate.the installation of the new CCD. organized to complement the existing bolt because it was very influential in the position of the CCDafter that the service mode, COPIER - FUNCTION - CCD - OKto end
            firdaus +(62)8195002007 firdaustrish@ymail.com
