Hi Guys!
I've got a problem with a Canon IR2020. It has ttle lines on the image, thought it is the failure of the drum, as its life was 55. Well After I changed for a new drum the lines were still there, even getting bigger. If I get the drum out , on the surface of the drum there were the same lines in toner.
I thought it must be the developer or it's cylinder.So I got it out from the machine. It's not big thing that get it out ( the toner cover and the drum puller ) so after I got it out I found a little plastic roller inside . I dunno what it's diameter is 8-10mm. I've done developer changind before several times, but I've never met with this roller.
so I put another developer into the machine. the result was the same.Even I copy a blank paper it did the same lines.
I don't know what could be that. I'm really out of idea. maybe laser unit, but the lines???
Or DC panel?
Or DC panel?
