Canon iR 3320i Hard Drive
  • iscott
    • Mar 2010
    • 344
    I need a formated HDD for a Canon iR 3320i anyone know where I can get one?
    If I can get the Firmware I think I can up load it on a after market HDD.
    Any ideas?
  • teckat
    • 16083
    Re: Canon iR 3320i Hard Drive
    Any ideas?
    You first need to FORMAT the HDD in the printer with the SST(CANNON SERVICE SUPPORT TOOL)
    In that SST program u must have the iR2220 Firmware loaded in it. The 2220 firmware will have a Format file listed.
    u then need either a OEM Canon HDD or any of the supported HDD's listed below(search online)
    u can also Modifying theHDD Descriptor. if your HDD is not accepted while using the SST in this model series-
    If the HDFormat file for the model you wish to format is Editable you can create a new entry in the file to allow it to support your hard drive.
    You will need to determine the model of the HDD you are trying to format to begin. The model will have been
    displayed in the error message from the SST. it is also printed on the outside of most HDD's.
    see PDF FOR INSTRUCTIONS>>SST HDD Not Found.pdf
    HDWN 'FUJITSU MPC3032AT
    HDWN 'FUJITSU MPD3043AT
    HDWN 'FUJITSU MPE3064AT
    HDWN 'QUANTUM FIREBALL CX6.4A
    HDWN 'QUANTUM FIREBALLlct10 05
    HDWN 'QUANTUM FIREBALLlct08 04
    HDWN 'QUANTUM FIREBALLlct15 07
    HDWN 'FUJITSU MPF3102AT
    HDWN 'TOSHIBA MK6014MAP
    HDWN 'TOSHIBA MK6015MAP
    HDWN 'IBM-DJSA-205
    HDWN 'IBM-DARA-206000
    HDWN 'FUJITSU MHK2060AT
    HDWN 'ST34311A
    HDWN 'ST34313A
    HDWN 'ST310211A
    HDWN 'FUJITSU MPG3102AT E
    HDWN 'QUANTUM FIREBALLlct20 10
    HDWN 'TOSHIBA MK1016GAP
    HDWN 'IBM-DJSA-210
    HDWN 'IC25N006ATDA04-0
    HDWN 'FUJITSU MHN2300AT
    HDWN 'TOSHIBA MK6017MAP
    HDWN 'IC25N010ATDA04-0
    HDWN 'Maxtor 2B020H1
    HDWN 'MAXTOR 4K020H1
    HDWN 'IC35L040AVER07-0
    HDWN 'WDC WD300AB-00BVA0
    HDWN 'IC35L020AVER07-0
    HDWN 'SAMSUNG SV2001H
    HDWN 'Maxtor 2F030J0
    HDWN 'ExcelStor Technology J120
    HDWN 'SAMSUNG SV0211H
    HDWN 'IC25N010ATCS04-0
    HDWN 'ST340015A
    HDWN 'TOSHIBA MK2023GAS
    HDWN 'IC25N020ATMR04-0
    HDWN 'SAMSUNG SV0221N
    HDWN 'FUJITSU MHT2020AT MF
    HDWN 'ST92011A
    HDWN 'SAMSUNG SV0411N
    HDWN 'HDS722540VLAT20
    HDWN 'ExcelStor Technology J640
    HDWN 'Maxtor 2F040L0
    HDWN 'SAMSUNG SP0411N
    HDWN 'WDC WD400BB-22HEA0
    HDWN 'WDC WD400BB-22JHC0
    HDWN 'HDS728040PLAT20
    HDWN 'ST340014A
    HDWN 'TOSHIBA MK4032GAX
    HDWN 'Hitachi HTS541640J9AT00
    HDWN 'FUJITSU MHV2040AH
    HDWN 'WDC WD800BB-22JHC0
    HDWN 'ST940210A
    HDWN 'ST940818AM
