Canon iR C3220 Keep warming up....
  • truongson
    • May 2011
    • 67
    I have 2 Canon iR C3220, The first keep warming up... for along time, if i turn on the printer it is warming up like this picture all day, i saw the fuser is runing and so hotDSC02407.jpg
    Have any idea for me ? Thanks
  • sgcopiertech
    Re: Canon iR C3220 Keep warming up....
    this issue has already been discussed in detail in a few post, try searching if you want a more detailed explanations. a summary :
    machine warming up is likely caused by 1 of your drums reaching their limit or can be the chip
    booting up: try reseating the pcb's on your mainboard
    goodluck
    • teckat
      • 16092
      Originally posted by truongson
      I have 2 Canon iR C3220, The first keep warming up... for along time, if i turn on the printer it is warming up like this picture all day, i saw the fuser is runing and so hot[ATTACH=CONFIG]11850[/ATTACH]
      The second is keep booting like this picture [ATTACH=CONFIG]11851[/ATTACH]
      Do the easy first>
      Check your Drums> are they old ?/ remove & re-seat them if not-
      Check in service mode, * 2 & 8 *, under Copier > display > Dens. Look at the value for each individual color. The normal value would be between zero and one. If you have a color with a value around four or five you have an issue with the toner/starter concentration level for that color. By replacing that color drum unit you may resolve the issue
      also if u can get in service mode- check for E004 codes
      Next>>>>>>>>>>>>
      1-Remove the Delivery Vertical Path Unit on the left side of the machine. You will see a photo sensor PS5 Fixing Feeder Unit Open/Close Sensor sandwiched between two micro-sensors that actuate when closing the Fixing Feeder Unit. Clean that photo sensor as it fills up with dirt and dust.
      iR3200 Fuser Switches.JPGDoorSw_1.jpgDoorSw_2.jpgDoorSw_3.jpgDoorSw_4.jpgDoorSw_5.jpgDoorSw_6.jpgDoorSw_7.jpgDoorSw_8.jpg
      2-Remove your memory DIMMS / Clean ends & re-seat them/ if there are two-one may be bad
      3-Clean and re-seat other PCB's
      • teckat
        • 16092
        also read this pdf about cleaning PCB's & re-positioning
        it effects all iR's
        , even though your printer is not listed
        Board Cleaning_TP07 094[1].pdf
        • truongson
          • May 2011
          • 67
          Thank you Teckat, The printer is working on well now when changed the black drum .
          • teckat
            • 16092
            GOOD FIND~~~~~~~~~
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Curiosity begs me to inquire,, what percentage was the drum at when you replaced it??
              • truongson
                • May 2011
                • 67
                I swap the drum from the machine which keep booting up in to the machine which keep warming up, and then the one which printer keep warming up to be okie, The Drum I saw, by my eyes is the same to the one which has probblem.
                But when i go to service mode with *28* -> Display -> Dens I saw the "Black" show : -4.58, while others show around -0.45 that is the resean I swap the Black Drum. After Swap, I go to the service mode again, the Dens of Black to be better, it is show around -1.25 and printer is working on well .
                • teckat
                  • 16092
                  I now see u had two printers with similar issues/ miss read your post
                  as I noted u need to keep on top of DRUM counters/& usage %
                  good luck-
