what is 602-0001 on image runner 2200
help
Re: help
E602
0001 A mounting fault of the HDD is detected when the HDD is started up from
the BOOT ROM.
0002 A data read fault of the HDD is detected when the HDD is started up from
the BOOT ROM.
Main cause The wiring is faulty (short circuit, open circuit). The HDD is faulty. The
main controller PCB is faulty. -
Accidents don't just happen. They must be carelessly planned.Comment
Re: help
try to switch on machine holding 1&9 buttons.if hd is ok clusters will fall automatically in screen and disply will get filled and download mode will come.swtch off and on .prolem solved? if no clone hard disc with "hd clone "software.tryComment
