IR 3230 - How do I empty the waste toner tank
  • russell915
    • Jul 2025
    [Error Code] IR 3230 - How do I empty the waste toner tank
    I have just received a Canon IR3230. It states that the waste toner cartridge is full. Where do I find the waste toner tank on this unit and how do I empty/replace.
    thanks for your help
  • TEC DOG
    • Sep 2011
    • 113
    Re: IR 3230 - How do I empty the waste toner tank
    Need to call canon tech.
    • russell915
      This printer is not under a maintenance contract. I don't understand why I need to call a Canon tech. There has to be a procedure that someone can share with me short of me having to call someone in and pay out the nose for something I can easily do with some guidance.
      • HenryT2
        • 962
        Check in your Operator's manual : It probably shows how to empty the WTB or if you do not have a manual and are NOT a tech...Call in a tech to handle this for you.
        You can probably get the manuals ( IF YOU ARE A TECH ) from Manuals 4 U
        "The Serenity Prayer" . . .
        God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
        • russell915
          thanks....I have the full compliment of manuals. I searched both the electronic media for the WTB and also paged through the paper manuals. There was no reference to it.
          I would not have posted here prior to researching the manuals and various online sources.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5013
            There was no reference to it because you need a screwdriver to get box.
            • charm5496
              • 2387
              I could go for a screwdriver right now!!!!
              • teckat
                • 16083
                U buy one new container/ FM2-0303-000)
                emptying is a mess
                Point to note after attaching the waste toner
                receptacle
                After attaching the waste toner receptacle, move the
                waste toner full detection lever up and down to
                make sure that the lever is moved smoothly. Faulty
                detection may be resulted if the lever is caught in
                something and is not moved smoothly.
                • russell915
                  emptying is a mess
                  receptacle
                  Thank you so much for your answer. The pictures told me everything I needed to get this done. And I will certainly order a new recepticle rather than emptying.
                  Thank you
                  • teckat
                    • 16083
                    Bright idea.jpgfor once; we have someone who listens rather than experiments
                    good luck
