canon 3300-e 315
  • vj200729
    print mate
    • 81
    canon 3300-e 315
    one canon ir3300 shows e 315 code and display automatically get switched off.this machine already shows "scanning and printing" but no copy coming out since last some days .can anybody suggest any solutions on your experience?
  • hari_4848
    • 91
    Re: canon 3300-e 315
    Any of the following is true in the image processing by the main controller:
    # The image data has a fault
    # The encoding/decoding operation for image data has a fault
    # The image processing element of the main controller PCB has a fault
    • vj200729
      print mate
      • 81
      is there any solution?
      • charm5496
        • 2387
        The troubleshooting guide in the Service Manual lists the Main Controller or the Hard Drive Unit as possible causes of the problem. If that doesn't fix the problem, another possible cause may be the Ram on the Main Controller.
        • charm5496
          • 2387
          If you have a sub-code to pass along that would be helpful in narrowing down the possible causes to your issue.
          • vigour
            • Aug 2010
            • 1038
            do you have fax on that unit.
            what is your system software version.
              • 16083
              Sub-Code is
              First clean and re-seat the DRAM on the Main Controller pcb.
              Then power up the copier holding down the 1 and 9 keys to perform a Hard Disk Drive defrag / scan disk operation. ( This will take 20 to 30 minutes to perform the operation.)
              • vj200729
                print mate
                • 81
                it was due to hard disc,thanks
                  • 16083
                  good find-
                  what did u actually do for repair / solution procedure could help others
