Canon 1024F error after working fine: Change papersize tray: Env
  • nikseldon
    Hello,
    After messing about with the printer (Canon 1024F) and trying to convince it to print on a C5 envoelope I finally managed to convince it to work. It now loads the envelope from the Stack bypass, prints perfecty fine on a C5 envelope and then gives the following error:
    Change papersize
    tray: Env
    This is highly annoying because every time I print an envelope I have to manually cancel the printing job, otherwise no further printing can be done.
    How to I fix this so I don't get an error after printing?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: Canon 1024F error after working fine: Change papersize tray: Env
    Did you change paper tipe settings?
    • nikseldon
      Yes, the paper type is correctly set as Envelope C5, and it also prints correctly. Just that it gives an error at the end, considers it did not print and will not print anything else until I cancel the print job.
      These are the settings I have on the printer:
        • 16083
        [ATTACH=CONFIG]13210[/ATTACH]
        What App are u using to print from ???
        did u do a MF tray width adjustment in service mode ????
        • nikseldon
          I am printing from Microsoft Word 2007 and the page size is set correctly in the application. Also it is set to Envelope C5 in the Advanced settings before print.
          I did not did not do MF tray width adjustment in service mode since I don't really know what that is or how to do it.
            • 16083
            when using Microsoft Word-for envelope printing on iR
            Setting the proper Feed From location in the Printing Options section of the Envelopes and Labels Window in Word.
            The proper Feed From location is AUTO.
            4) At the bottom of this Window, you will see the Feed From drop down Menu.
            5) Set this option to AUTO
