Canon ir 5570 sharescan op
  • jake24482
    • Apr 2011
    • 116
    hi i need help to setup sharescan op on canon ir 5570. i never setup share scan op if someone can help me with some sort of information please.i really
    appreciated. thanks
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: Canon ir 5570 sharescan op
    First, you will need to setup a shared folder
    1. Go to your desktop or another location such as C drive.
    2. Right click, New > Folder
    3. You should now have a new folder on your desktop
    4. Right click on the folder and rename to SCANS
    5. Right click on this new folder and select “share” . Note this may differ slightly depending on what version of windows that you have.
    6. If there are users shown as a list, select the individuals that you wish to grant access to, alternatively select “everyone”
    7. The folder should now change to confirm that it is now shared.
    If your Canon copier is an i model (it will have an i at the end of its model number such as iR2380i ) or if it is fitted with a universal send kit, then the machine will have the ability to push scan. This means that you can send a document straight from the machine to your new scans folder.
    If you will be scanning regularly to this folder we recommend that you set up a one touch button on your copier.
    The process will vary slightly depending on the model that you have but the setup will follow this method:
    1. Press “one touch” and setup a new destination.
    2. Select the type of document destination as “file” and SMB
    3. Select “browse” this will display your network name, depending on the naming convention that is used, or may simply display “workgroup”
    4. Highlight the domain and select your computer from the list. If the network is quite large you may have to navigate through sub-networks to find your PC.
    5. You will now be asked to provide your computer network logon and password – this is the logon used to authenticate you on your PC / network.
    6. Once you have provided logon details you will see any shared folders on your PC.
    7. Select your “scans” folder and save the setting.
    8. You have now setup a one touch button for scanning.
    9. To send a scan to your PC, place your document in the machine and simply press “One Touch” you will see your scans folder displayed, select this and press the green start key to send the file.
    10. On returning to your PC, open your scans folder and you will see the new file inside.
    • jake24482
      • Apr 2011
      • 116
      do i need to change any thing in copier
      • zoraldinho
        • Mar 2008
        • 5013
        With sharescan you mean scan to folder i hope.Do you have send kit insalled??
        • jake24482
          • Apr 2011
          • 116
          how can check if i have usend
          • jake24482
            • Apr 2011
            • 116
            on display it shows sharescan op
            • zoraldinho
              • Mar 2008
              • 5013
              This is not candid camera i hope!Check on the screen on your copier if you have this option.
              or maybe this option?
              • KL568
                _
                • Feb 2011
                • 324
                [ATTACH=CONFIG]13676[/ATTACH]
                [ATTACH=CONFIG]13677[/ATTACH]
                Hi, all
                Think Jake24482 is referring a MEAP application that is in the copier, here is the link
                eCopy ShareScan OP
                Jake,
                Have you try using RUI of the copier? Or some software utility from eCOPY to configure it?
                Sorry, Zoraldinho
                Did not view your full reply with 2nd picture insert.
                Last edited by KL568; 12-29-2011, 04:17 PM. Reason: Apology to Zoraldinho double query Jake
                • jake24482
                  • Apr 2011
                  • 116
                  on screen it just shows sharescan op on to left corner and in middle it shows add a device or connect with devicephoto.JPG
                  • zoraldinho
                    • Mar 2008
                    • 5013
                    Take your time and read carefully.
                    AdminGuideCanonMEAP.pdf
                    • jake24482
                      • Apr 2011
                      • 116
                      yeah it will take a minute but i will read it
                      thanks alot for the info
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        Whoa - hold the phone here - eCopy ShareScan is a TOTALLY different product!
                        While ShareScan and Universal Send both scan, that is where the similarity absolutely ends.
                        Apparently, this machine was purchased used or moved from another location.
                        The picture of the screen you supplied is your machine attempting to connect to a computer running ShareScan Services Manager. ShareScan OP (Open Platform) is a MEAP,(Java) application that gets installed on the Canon machine, and runs as a MEAP application.
                        Since you don't have the software, and way more importantly, the LICENSE for the software, you're pretty much out of luck for "push" scanning.
                        • mramlawi
                          • Jul 2011
                          • 838
                          I didnt use it this Option Yet thanks for the info zoraldinho
                          Distinguished road makes you jewel in rough
                          • jake24482
                            • Apr 2011
                            • 116
                            thanks alot all of guys
                            • zoraldinho
                              • Mar 2008
                              • 5013
