Inner Booklet Trimmer-A1 / DEQ01861 and Earlier
Countermeasures against E5BA-8002/E5A3-0002 Error Codes and 11A4/17A4 Jam Codes
When the Inner Booklet Trimmer-A1 is used, the following Error and/or Jam Codes may occur:
Error code:
E5BA-8002 / Description: Error in the Front Estrangement Motor.
E5A3-0002 / Description: Error in the Registration Motor.
Jam Code: 11A4 / Description: Inner Trimmer inlet sensor stationary jam.
17A4 / Description: Inner Trimmer inlet sensor stationary jam.
Main Engines and Finishing Devices that work in conjunction with the Inner Trimmer-A1.
Copier Main Engine--Finishing Device-------------Error Codes------------Jam Codes
iR ADV 8000 series--Stapler/Booklet Finisher-D1---E5BA-8002--------------11A4
iR ADV C9000 series--Stapler/Booklet Finisher-A1--E5A3-0002---------------17A4
image PRESS 1135 series---Stapler/BookletFinisher-AG1/AG2
see pdf---------TP12.pdf
Error code:
