Canon Ir2230 white line
  • tibbs
    • Aug 2008
    • 225
    Hello friends, i have a canon Ir2230 with a white line running across the copies. If you make a black copier it comes out perfect but if you make a normal copy it comes out with a white line. I have changed the transfer roller, the laser unit, the developing assy, drum unit, cis and i have checked the blank exposure unit. Any help with this one will be most appreciated. Also its not the fuser.
    Thanks much in advance
    Tibbs
  • mramlawi
    • Jul 2011
    • 838
    Re: Canon Ir2230 white line
    Hello
    it will be better if you attach a sample check the developer ,transfer ,try to make print out test
    Distinguished road makes you jewel in rough
      Hmm there's not much left to change.
      Jam the machine to give some indication of where its happening does it happen with PG test prints?
      • teckat
        • 16083
        Tibbs
        is issue on Prints and Copies or on just one of them
        POST COPIES OF THE ISSUE
