canon iR adv C9060
  • tech.gasm
    • Sep 2010
    • 39
    [Jamming] canon iR adv C9060
    Hello,I hv canon iR adv C9060 whereby the separation roller isn't functioning for all 4 trays.Its picking up like 6sheets at once...= jam & paper wastage.After wiping them,they pick up a little bit but go back to their ways eventually; exchanged paper feed units,no change.(meter reading_220k)Any ideas anyone??
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4998
    Re: canon iR adv C9060
    all 4 trays?? What type of paper do you have?Appropriate rollers?
    Pickup Roller FC5-2524
    Feed Roller FC5-2526
    Separation Roller FC5-2528
    • tech.gasm
      • Sep 2010
      • 39
      The paper weight is 100gsm,the rollers are the ones the MFD came with(it began operations in Sept 2011).Also tried with 80 gsm paper to give me the same results....
      • Rachid.Akli
        • Oct 2011
        • 595
        Hi,
        It's, really, a strange issue!!!!!
        Even without sep rollers, pick up rollers seldomly take six sheets???
        I suggest: 1- You change the type of paper.
        2- Verify if the pickup-rollers move up and down during printing.
        3- Download the latest system version.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • Rachid.Akli
          • Oct 2011
          • 595
          Hello everybody
          What's new about your machine? Is there any feedback?
          Rachid.
          • tech.gasm
            • Sep 2010
            • 39
            After observing it for a while,the MFD started behaving well but now its back to multiple pick-up;this is even after changing the pick-up rollers.
            As for verification of the pickup rollers moving up n down,its affirmative.
            The paper type used on the MFD is 100gsm & that's the only type used on that MFD ever since it was installed.
            The paper type on the MFD setting is Plain 2_91-105gsm.
