This unit is the mutant spawn cousin of the HP CM2320 and there is some procedure that has to be performed in a service, or secondary service menu to rotate the driveshaft to allow proper access to the roller to remove it.
I know you just need to do the "menu",2,8,"menu" to enter service mode, but is there another command to enter a different menu?
