Canon IRADVC5045 E0003-000E
  • rayjeek
    • Jun 2010
    • 239
    [Error Code] Canon IRADVC5045 E0003-000E
    I will attend IRADVC5045 with error code E0003-000E on Monday. Just wondering if its actually a faulty fx heater that will require fixing film to be changed. Any known fix for this error would be much appreciated. Thanks.
  • teckat
    • 16083
    Re: Canon IRADVC5045 E0003-000E
    clear error
    Try re-seating the Fixing Unit, or cleaning /inspecting the Fixing Drawer connector from small pieces of paper
    • rayjeek
      • Jun 2010
      • 239
      Thanks Teckat., will try just that and let you know.
      • arielcanon
        • Mar 2012
        • 106
        e003...
        Learning never ends..
        Never give up, where there is a wheel there is a way..
        • rayjeek
          • Jun 2010
          • 239
          Problem solved. It was the fixing film unit.
          However I noted that the MFD throws up E575 when stapling. The gripper does not fully eject the sets of paper suggesting a break in gripper rail. I will get a new one together with gripper assy and update firmware, hopefully this will resolve the problem. Any known fix welcome.
          • CanonSco
            Man About Town
            • Jul 2010
            • 368
            Will be the rail itself more than likely. I have only had to replace a few gripper assemblies themselves. ( other than replacing EVERY single one I have for the "new" type some time ago )
            An easy fix.
            Yes, I am a nerd.
            Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
            • rayjeek
              • Jun 2010
              • 239
              For the E575 error code: CanonCo was right, it was the gripper rail which was broken into two. Replaced same and updated firmware ok. Thanks to all.
