IR2520 Machine serial number can modify
  • ts-lx
    • May 2011
    • 59
    thank you
  • spectraindo
    • May 2008
    • 313
    Re: IR2520 Machine serial number can modify
    Modifying serial numbers is a crime!
    • Brian8506
      • 1664
      Sure you can modify it. Get a black marker and write what number you want it to be right across the front cover. Can we help you roll the meter back too? Tell your customer the meter clicks 10x for each page therefore you really only have 100,000 copies not 1,000,000
      • ts-lx
        • May 2011
        • 59
        I want to change the electronic counter display in the machine serial number
        • Brian8506
          • 1664
          You want to change the meter count or have different counters on the display?
          • TechSoupJM
            Any attempt to change the S/N of the Engine will most likely result in a E355 code locking up your machine.
            Permanent damage can result to the S/N PCB and the Counter PCB will be trash also.
            I have also seen these Main Controller PCB's corrupted to the point of no repair also.
            The Main Controller PCB and the Counter PCB are service replaceable items. However, the S/N PCB is NOT a service part. To get a replacement of this item requires the direct assistance of the Canon Hardware Engineering team.
            You will most likely be throwing that machine away if these events were to happen.
            • JustManuals
              • Jan 2006
              • 9838
              If we told you how to do it, we'd have to kill you too.
              • ts-lx
                • May 2011
                • 59
                It seems that no one is able to do
                • jose dai
                  • Dec 2008
                  • 25
                  unfortunetly u cant call for canon service support only they can help u
                  • Brian8506
                    • 1664
                    OK so I'll be the one to ask the $64,000.00 question. Why do you want to reset the meter???
