CLC3200 duplex problem
  • xcopytech
    • Aug 2006
    • 1753
    Have CLC3200 machine which can not make duplex copy or print.
    Single side copy and print are fine.
    Jam code is 010A.
    Test duplex motor from diagnostic and motor do not work.
    Tried Duplex unit from another working machine and still not duplexing.
  • Van Steal
    • 177
    Re: CLC3200 duplex problem
    you need to replace the duplex motor driver pcb, you'll find it at the back of printer attached to the plate were the power for optional two lower trays plugs in.
    • xcopytech
      • Aug 2006
      • 1753
      thanks for answer.
      will check on monday and post result here.
      • mramlawi
        • Jul 2011
        • 838
        Yea as van said replace the duplex pcb which located on the back of the machine but make sure to get same pcb cos theres 2 kinds of pcb.
        Distinguished road makes you jewel in rough
        • teckat
          • 16092
          Originally posted by xcopytech
          thanks for answer.
          Failure of one BOARD effects the other Pcb. / if u replace the Driver pcb. and Fuse pcb is bad -it can cause the good driver pcb to crap out/ this works in the reverse also-
          if u have a bad FUSE on the FUSE PCB. the Duplex Driver Pcb will not function (as in a loss of 24v on FU26 >check J68 to verify the presence of 24v)
          also replace the FUSE PCB at the same time as Duplex Drive PCB/ there is a fuse that on the board that deteriorates and has low voltage across it- these fuses usually check good & not open for continuity but when needed voltage is not exact for signals they cause issues-
          Tech tip on duplex issues on this model>>>the black plastic duplex guide tray warps from the heat>causing duplex issues(lines/jams/& cq problems >>>
          upper duplexing guide FB6-3581-000
          these FUSES need to be checked with power on/ difficult on this model// that is why u should always carry this small cheap fuse pcb with you// saves time and headaches
          3.3 Volts DC have pink wires FU11 3.3vdc J59-1 Power distribution PCB J1502-1
          FU11 3.3vdc J59-2 Power distribution PCB J1502-2
          FU13 3.3vdc J60-3 Power distribution PCB J1501-3
          FU13 3.3vdc J60-4 Power distribution PCB J1501-4
          FU14 3.3vdc J61-5 Fax G3-G4 J560-3
          FU14 3.3vdc J61-6 Fax G3-G4 J560-4
          FU15 3.3vdc J61-7 Fax G3-G4 J560-6
          FU22 3.3vdc J64-9 DC controller J100-9
          FU22 3.3vdc J64-10 DC controller J100-10
          5 Volts DC have brown wires
          FU16 5vdc J61-13 Fax G3-G4 J560-11
          FU17 5vdc J60-1 Power distribution PCB J1501-1
          FU17 5vdc J61-11 Fax G3-G4 J560-9
          FU17 5vdc J61-12 Fax G3-G4 J560-10
          FU23 5vdc J71-5 DC controller J106-1
          FU27 5vdc J68-3 Duplex delivery PCB J440-3
          12 Volts DC have orange wires
          FU12 12vdc J59-5 Power distribution PCB J1502-5
          FU18 12vdc J60-8 Power distribution PCB J1501-8
          FU31 12vdc J64-7 DC controller J100-7
          14 volts DC
          FU32 14vdc J65-1 NO output
          24 Volts DC have red wires
          FU20 24vdc J62-1 H3 Fixing unit J802-4
          FU21 24vdc J64-1 DC controller J100-1
          FU21 24vdc J64-2 DC controller J100-2
          FU24 24vdc J74-1 Power distribution PCB J1509-2
          FU24 24vdc J66-1 Fax PCIP J559-1
          FU25 24vdc J67-2 Reader J565-1
          FU25 24vdc J67-3 Reader J565-2
          FU26 24vdc J68-1 Duplex delivery PCB J440-1
          FU28 24vdc J70-1 HV2 sub PCB J91-1
          FU29 24vdc J70-3 Drum ITB motor J93-1
          • xcopytech
            • Aug 2006
            • 1753
            Thanks to all Replaced Duplex motor driver PCB and FUSE PCB and everything is fine now.
            • Van Steal
              • 177
              Good Job, thanks for feedback
              • teckat
                • 16092
                kool~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
