Canon IR 400 paper jam while two sided printing
  • parimalj
    • Jul 2025
    [Jamming] Canon IR 400 paper jam while two sided printing
    Hi Dear Friends!
    When I am making two sided copy or print, the paper gets jammed.
    Also for example I am going to copy single sided copies in large numbers like 100 or more than hundred ( single sided), it starts jammig paper after 40-50 copies, it's consums too m uch times and wastes papers as well.
    Can any body please help me regarding this?
    I also have a canon IR 2200/3300 which jams A3 size paper near the paper out put with a noice.
    Any sollution frends?
  • ESA
    Re: Canon IR 400 paper jam while two sided printing
    Have you tried moving your paper to a different drawer to rule out worn pickup rollers. As well if you put paper in landscape position is the results the same? The ir400 is a very old machine. Other than pick up roller changes you may have a interesting time sourcing parts at a decent price. I would start with the two ideas I gave you for a fast test.
