Dept ID Canon
  • hurley412
    Dept ID Canon
    Hi, we have a Canon 3200 and we want to keep track of every users print totals. The problem we're having is that a couple of computers have settings that do not require a dept ID password to print. What do I change to remove that?
  • ESA
    Re: Dept ID Canon
    Are they PC's or Mac's? For PC's goto control panel, printers / faxes (xp). Choose your printer goto properties and remove the dept ID that is recorded here. If using a PS driver with fiery you will not be prompted. There is a number of combo's here but for the most part look at the dept Id in the printer properties and make sure it's empty.
    • hurley412
      Re: Dept ID Canon
      thanks for the reply esa, that does work for some of the computers but for others its not even an option to record a dept it.
      • ESA
        Re: Dept ID Canon
        Ensure all computers are all using the same version of the driver. Back in early days there would be an ini file that would be altered to prevent Id prompts. I imagine it's a reg control now. I would remove any current driver and reinstall using the self setup. Make sure your checking off the account code feature when your prompted during the install. I forgot the actual name but it is a check box through the setup. It's likely this feature is not enabled on these computers print drivers
        • Chameleon
          • Nov 2011
          • 200
          Re: Dept ID Canon
          Originally posted by hurley412
          ...that do not require a dept ID password to print. What do I change to remove that?
          I believe the setting you are looking for is under ADDITIONAL FUNCTIONS > SYSTEM SETTINGS > DEPT ID MANAGEMENT > SET "ALLOW PRINTER JOBS WITH UNKNOWN IDs" TO "OFF"
          If this is set to "ON" it will print any job sent to it with or without a Dept ID, which if I understand you correctly don't want since there is no tracking. Set it to "OFF" and it will only print jobs sent with an ID and drop the rest. Then follow ESA's instructions on adding the ID in the print driver.
          The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
          • RSFarrer
            • Sep 2008
            • 20
            Re: Dept ID Canon
            using the RUI/web interface, I un-check most of the boxes in setting up Dept IDs. this also frees up faxing and scanning from having to use a dept ID.
            I also don't use a PIN unless necessary so even though the window will still be on the screen, the end-user only needs to enter in their dept ID to gain access.
            • jarwil
              • Jun 2009
              • 61
              Re: Dept ID Canon
              make sure you get Device Status in the print driver so the driver knows that Dept ID's are on
              • Mina Banoub
                • May 2011
                • 50
                Re: Dept ID Canon
                Try this
                Go to your printer properties(on those computer that don`t ask for an ID no to print) >device settings>job accounting (make sure to check mark this option)
                • hurley412
                  Re: Dept ID Canon
                  Thanks for the help so far guys. I got it working for all of the Windows machines but we have 2 MAC's that are being asked to enter a dept id. Can you help me with this?
                  • vigour
                    • Aug 2010
                    • 1038
                    Re: Dept ID Canon
                    which driver are they using on the mac?
                    PS
                    Its quite tricky
                    At the bottom of Fiery Notes, you can enter ID and password
                    • KL568
                      _
                      • Feb 2011
                      • 324
                      Re: Dept ID Canon
                      Hi,These 2 Mac, are they able to print after inputting the correct Dept IDs?If yes, that basically indicate it able to print.For Mac, have you done a presets with Dept IDs saved in it? This will not have that pop up requesting users to key in
