Canon IR400
  • Larryo
    • Jul 2012
    • 18
    Canon IR400
    Hello all. Working on a very old Canon IR400. Registration varies from copy to copy. Need a part number for the reg. clutch. Parts book only shows CL1, CL2, etc. Need the main reg. clutch p.n., please.
  • teckat
    • 16092
    Re: Canon IR400
    FH7-5768-000/ I believe CL1 is Reg clutch
    I would also look at -CL3=Vertical path roller clutch=FH7-5770-000
    Feeding roller and the separation roller make sure that only one sheet of paper is moved to
    the feeding path; the paper is then moved as far as the registration roller by the No. 2 registration
    roller and the vertical path roller.
    The drive of the vertical path roller and the No. 2 registration roller is switched by turning on
    and off the vertical path roller clutch (CL3).
    The drive of the registration roller comes from the main motor (M1) by way of the registration
    roller clutch (CL1)
    .---CLICK ON PIC BELOW
    • Larryo
      • Jul 2012
      • 18
      Re: Canon IR400
      Thanks a bunch teckat. Replaced cl1 and cl2 and cleaned all the rollers in the path. Works like a champ! Thanks again!!
      • teckat
        • 16092
        Re: Canon IR400
        COLOR HAND.jpggood find, thanks
