what was the model number for an analog machine that was released which had a laser to do the lead edge blank (also had faulty light sensitive drums when it first came out). np4835? or something like that . cheers
Quick question for aging canon techs
Re: Quick question for aging canon techs
NP4835 and NP4335. Also had the infamous colour changer!!!Comment
By definition, analog means sans laser. The NP-4835 used blank lamps like all it's predecessors. The first Canon I know of with a laser was the GP-200, which was just a NP-6030 retrofitted to be digital. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
NP-1100=1969/70 Japan first PPC
NP-70=1972
CANON NP-L7= 1972
NP-8500=1978
LBP-10= Using a Semiconductor Laser=1979
First CANON Fax= FAX 601=1980
NP-8500 SUPER>135CPM=1981
First PC=PC10/PC20=1982
PC Printer 70>first plain-paper reader/printer=1984
LBP-8/CX>world's smallest and lightest laser printer=1984
CLC1=1987
CLC 500=1989
CLC 200=1989
NP-9800=1990
CLC 300=1991
CLC 550>anti-forgery technology,is introduced=1992
GP55=1992
NP-6030=1992
CLC 550/350=1993
CLC 800/700=1994
CLC 320=1996
CLC 800L/800S/700L/700S=1997
CLC 1000=1997
CLC 2400=1998
CLC 900/950=1998**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Oh, wow....trivia time to make us feel old! Not counting CLC's or laser printers which go way way back(see tekcats list) the first Canon black & white digital laser copier I was trained on was the GP-30/GP-55 then the Gp200 came out like a year or so later. You're right though about the GP200 being a redesigned NP-6030.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
Correction duly noted. I forgot about the GP30 and GP55. There were only two in the branch, under a different tech. =^..^=If you'd like a serious answer to your request:
NP 120/125 cold pressure fusing, never get a fuser code. NP 400/ 500 ran faster than it could. NP 30 50 60 F'n liquid.. NP 350 450 with color DV units that got broken all the time. And the POS of all Canon the NP 200 with the movable platen that changed drum charges whenever it felt like it. Remove the cleaning corona, 1 month later replace the cleaning corona. I was hired at a Canon dealer because I knew how phones worked. I was troubleshooting G1 faxes. 1984Why do they call it common sense?
If it were common, wouldn't everyone have it?Comment
Attached FilesComment
