Canon iR5055 Hole Punch - Misalignment
  • Jamesu
    • Mar 2012
    • 101
    Hey all,
    Having a bit of a problem with the hole punch unit on a iR5055. If i'm doing a few copies the hole punch unit works fine, but if i want more and more documents hole punched then the holes will come out misaligned.
    I've also noticed that the unit makes a "quacking" noise (Sort of like a cog is missing). I'm guessing this is the problem but not sure on how to fix it?
    If i push down on the top of the hole punch unit while the machine is running it stops the problem, so it's almost as if theres a pressure problem somewhere.
    Hope someone can help?
    Have you tried turning it off and on? No...Oh, it works now!
