Canon 3200 Drum issue
  • dagoof
    Still learning...
    • 220
    I've found over the years I've literally wasted thousands on drums for the 3200 and the quality of them seem to be useless now - often after only 10-20% used they're laying down background scatter (1st print is fine, a little evident by 2nd, out of control by the 3rd).
    I've tried auto-gradiations, reducing print density etc but binning the drum is usually the only way. I just found an archived thread that says "all that you have to do it adjust the color that is overtoning in service mode level 2 down to a -2 and doing that and that alone will get your drums to go 80k or more". Does any know, are we talking about the DENS>T-SPLY settings here? (as I tried that and it didn't really help!).
  • charm5496
    • 2387
    Re: Canon 3200 Drum issue
    here is what I use to change on drums that were overtoning like you are describing. You can adjust the numbers however you like just keep in mind that this does affect the image quality and you need to power cycle and run auto gradation/calibrate after adjusting.
    TC-REF to 0
    DVTGT-M to -3
    NEGA-GST to 2
    • dagoof
      Still learning...
      • 220
      Thanks Charm, will give it a go!
      • charm5496
        • 2387
        you are welcome...and good luck!
        • V-P
          • Apr 2011
          • 679
          Maybe I am wrong but I always thought that if you "push" more on the drums after they reached 250%-300%, than toner consumption is higher.
          Is this true ?
            • 16083
            post some copies of those issues
            are u using OEM Drums/Toner ?/
            try this---------
            1-Turn off PASCAL in service mode. 2-Run CCD AUTO ADJ. 3-Turn PASCAL back on.
            4-Exit service mode and complete a FULL Auto-gradation.
            #1 & # 2 most important issues on those 3200 DRUMS/ TONER & SEPARATION is
            the ENVIRONMENT CONDITIONS of the Printer & % of COLOR COVERAGE
            have seen issues with
            HV1-SUB PCB / cause of Background issues
            Did u check the four bias tabs on the Drum Unit Cover. The bias tab may be pushed in and stuck. If the tab is stuck in, it will create a poor contact to the bias tab on the drum unit resulting in background on the copies. There is one tab for each drum.
            have seen this many times--------------in field
            • Canon.Tech
              • Mar 2009
              • 335
              If the same customer + machine were high use the drums would last a lot longer, I average around 300% on colour drums, less on the black as they start to leak at around 200%
              • dagoof
                Still learning...
                • 220
                Charm - no luck with that.
                Environmental will have a roll to play, these ones have been lying for a while, but others can be acting up after just a couple of weeks (again, usually Y). It's laying don vertical bands of black at the moment, but again, 1st sheet is always fine.
                Tekcat - is that Pascal in Service Level 1>Option>Body?
                Level 1>Function>CCD>CCD-ADJ
                Had tried that already.
                Checked the bias tabs (they're ok) but I'm guessing as a new drum often sorts it, that wouldn't be the issue?
                Thanks for the replies.
                  • 16083
                  Post pics on some of the issues !!!!!!!!!!!!!!!!
                  IN Level 2/COPIER>ADJUST (Level 2) screen
                  <HV-TR>
                  The adjusted offset doesn’t become valid unless all of the following 6 items are entered: 2TR-TGT, 2TR-SHR, TR-PPR, TR-ENV, TR-CLR and TRDUP.
                  The settings entered for all 6 items make up a single pattern. 8 patterns can be stored in memory.
                  2TR-TGT1/2/3/4/5/6/7/8 (Used to adjust the offset to the secondary transfer target current.)
                  Adjustment range: –5 to +5 (2 μA units) (Value at time of factory shipment/value after RAM clear: 0)
                  Increasing the setting value: Effective for images with toner spatter/water droplets.
                  Decreasing the setting value: Effective for images with white marks, white blotches,rough-textured half-tones.
                  2TR-SHR1/2/3/4/5/6/7/8 (Used to adjust the offset to the secondary transfer paper-portion
                  voltage.)
                  Adjustment range: –5 to +5 (100 V units) (Value at time of factory shipment/value after
                  RAM clear: 0)
                  TR-PPR1/2/3/4/5/6/7/8 (paper type item for secondary transfer offset adjustment)
                  1: Normal paper (Value at time of factory shipment/value after RAM clear: 1)
                  2: Recycled paper
                  3: Bond paper
                  4: Mother print
                  5: Card
                  6: Extra thick card
                  7: Special paper 1 (including labels)
                  8: Glossy paper
                  9: Special paper 2 (including Japanese paper)
                  10: Postcards/envelopes
                  11: Transparencies (color)
                  12: Transparencies (monochrome)
                  TR-ENV1/2/3/4/5/6/7/8 (environmental item for secondary transfer offset adjustment)
                  Enter value of COPIER>DISPLAY>MISC>ENV-TR.
                  1: Low-humidity environment (Value at time of factory shipment/value after RAM clear:1)
                  2: Normal-humidity environment
                  3: High-humidity environment
                  TR-CLR1/2/3/4/5/6/7/8 (color mode item for secondary transfer offset adjustment)
                  1: Full-color mode (Value at time of factory shipment/value after RAM clear: 1)
                  2: Monochrome mode
                  TR-DUP1/2/3/4/5/6/7/8 (one/two-sided item for secondary transfer offset adjustment)
                  1: One-sided (Value at time of factory shipment/value after RAM clear: 1)
                  2: Automatic two-sided
                  3: Manual feed two-sided
                  • dagoof
                    Still learning...
                    • 220
                    Thanks Tekcat, I've added a pic - converted it to B&W and adjusted levels to hopefully show it a little clearer.
                    Got vertical stripes at ~47mm intervals (possibly the diameter of the drums, cleaning blades marked it from sitting idle?) but there's also general background scatter that has a horizontal grain type pattern. All in all, pretty dirty copies!
                      • 16083
                      there are no cleaning blades in the drum units(there is an internal cleaning sheet in units , in contact with drum (reciprocating movement of 5 mm; cycle of 1.5 sec) only a blade to clean ITB--
                      forget about conversions /// post some color pg5's and a pg6 grid pattern
                      then post a copy of a text document from the glass
                      do not do any Color conversions /////////////
                      • Fer
                        • Nov 2009
                        • 267
                        I don;t see that much 3200s, but on 4080 series i suspect a decrease in durability. On full bleed/heavy stock customers we replace em between 10-20k. Were "in the old days" 50k was possable.
                          • 16083
                          Drums are tested and rated for 6% coverage/
                          full bleed color printing on these drums (not approved by Canon or Service Techs>
                          unless u want to keep on customer site toner & drums stock
                          • dagoof
                            Still learning...
                            • 220
                            Tekcat - should I be looking to up the value of every variant for each of the 6 sections e.g.
                            TR-PPR1 +2
                            TR-PPR2 +2
                            TR-PPR3 +2
                            All the way up to #8 for each PPR/TGT etc?
                              • 16083
                              TR-PPR1 +2
                              TR-PPR2 +2
                              TR-PPR3 +2
                              I could never understand those settings> usually increase to +3 on those red highlighted items
                              & check other value settings posted on rest
