Procedure to Prevent Error Codes Caused from Poor Contact of the Sub PCB�s
  • teckat
    • 16083
    [Error Code] Procedure to Prevent Error Codes Caused from Poor Contact of the Sub PCB�s
    see pdf
    Board Cleaning.pdf
    Procedure to Prevent Error Codes Caused from Poor Contact of the Sub PCB’s
    When one or more of the Sub PCB’s are not properly seated in their slot on the main controller
    there are multiple error codes that can be generated.
    Products Affected: Serial Numbers Affected:
    imageRUNNER C3170 / C3170U ---All
    imageRUNNER C5870 / C6870U ---All
    Color imageRUNNER C5180 / C5180i / C4580i / C4580 / C4080i / C4080 ---All
    Color imageRUNNER C2880G / C3380G / C2880 / C2880i / C3380 / C3380i -All
    Color imageRUNNER C3380G / C2880G / C3380i / C2880i / C3380/ C2880
    Color imageRUNNER C4580i / C4580i / C4580 / C4080i / C4080
    imageRUNNER C3170 / C3170U / imageRUNNER C5870 /C5870U
    BOARD CLEANING WILL HELP, NOT ONLY ON LISTED SERIES , BUT OTHER MODELS AS WELL
  • bipc
    • Sep 2009
    • 194
    Life is a learning continuum...
