Canon IR 4570 and a Doc Send
  • landspeeder
    • Feb 2010
    • 355
    I have a customer that uses a I/R 4570 with a attached Docsend...he scans to email, copier etc. He wants to get rid of the Docsend and use the 4570's user interface only..when he unplugs the docsend and pushes the copy button all it says is on or off line....how do you set up the 4570 to work the same as with a docsend but not with one connected?
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • teckat
    • 16092
    Re: Canon IR 4570 and a Doc Send
    U need to select ONLINE for Network Scanning
    select OFFLINE for Copying
    User Mode>Common Settings>
    System Control Settings
    auto online/offline-------auto on-line shift: ON/*OFF
    shift***----------------auto on-line shift: ON/*OFF
    ***If iR5570, iR3570, iR2870, or iR2270, indicated in the presence of a specific accessory (if model F, standard).
    Auto Offline Feature allows a user to have the Scanner within the imageRUNNER automatically go offline after a certain amount of time. This functionality is helpful because other features of the copier may not be enabled while the scanner is online.
    To enable Auto Offline:
    1) Select Additional Functions.
    2) Select System Settings.
    3) Select Auto Offline and set this to On.
    To set the time that the machine will automatically go offline (Auto Clear Time):
    1) Hit Additional Functions.
    2) Select Timer Settings.
    3) Choose Change Auto Clear Time.
    4) Enter the desired time in minutes and select OK. The time ranges from 0 - 9 minutes in one minute increments (0 = off).
    Under the Scan tab of the copier control panel's LCD screen, the scanner must be set to Offline.
    The scanner only needs to be set to Online when scanning with Network ScanGear/Color Network ScanGear. When push scanning, set this to Offline.
    • landspeeder
      • Feb 2010
      • 355
      The customer doesnt have Network Scangear and wants to scan...is this software/hardware and whats involved? Thanks for the info so far!!!!
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3945
        Is the Docsend non-functional, and if so, do they have an estimate to repair?
        The Docsend is a direct competitor for eCopy, and both are premium solutions which were not exactly cheap to purchase.
        • teckat
          • 16092
          Network ScanGear (pull scanning): "pull" scan, where a document is placed in the Printer and then your computer pulls the document into an application such as Adobe Photoshop,
          Network ScanGear v2.21
          Universal Send (push scanning)
          :Universal Send Kit-B1--9594A002AA
          Multi PDL Printer Kit-E1--9593A003AA
