Configuring the E-mail / I-fax Settings
via the RUI on the imageRUNNER 2016i / 2020i / 1023iF / 2018i / 2022i / 2025i / 2030i
The ability to configure the E-mail / I-fax Settings in the RUI of these models is available, but it will not show up in 'display mode'. The E-mail / I-fax Settings will only display in 'change mode'.
In order to configure the E-mail / I-fax Settings in the RUI, perform the following steps:
1. Launch the RUI in Internet Explorer (http://ip_address).
2. Log into Administrator Mode in the RUI.
3. Click on Device > Network on the left pane of the RUI. Look at the TCP/IP settings.
* The E-mail / I-fax Settings are under the TCP/IP settings. However, the E-mail / I-fax Settings do not display in the list of the TCP/IP settings. You must edit the TCP/IP settings to view them.
4. Click the [Change] button next to TCP/IP in the main pane of the RUI.
5. Scroll to the bottom of the resulting page. You will find the 'E-mail / I-fax Settings' here.
