Canon ir adv 6075 leaving spots and dark bands
  • A\ztech
    • Feb 2011
    • 57
    Hey Guys need your help I have a canon ir 6075 that starts leaving dark bands from lead to trail edge and is now leaving spots also. its starts off with a clean page after the 3 or 4 one is when the spots and bands start. I cleaned the drum and coronas with alcohol, cleaned cleaning unit and checked connections on developer. the bands are darker than the picture any ideas?dark spots and band.pdf
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Re: Canon ir adv 6075 leaving spots and dark bands
    There was a Tech pub about a cleaning blade causing some issues. I think teckat could pull some info on it.
    • vigour
      • Aug 2010
      • 1038
      If the spots are coming from the primary corona. cleaning will not work.
      the wires will cause dark bands also.
      cleaning blade will cause dark bands and spots too.
      modified cleaning blade and blade holder
      FL3-6291-000
      FL3-5194=020
      • A\ztech
        • Feb 2011
        • 57
        do I have to replace the whole primary assy. or just the two wires in it? Good stuff guys Thank you
        • vigour
          • Aug 2010
          • 1038
          only the 2 wires need to be replaced.
          the spring is different, you have to snip it to make a loop, or use the old style spring, or use the pre strung wires (FL3-4558)
          • SCREWTAPE
            East Coast Imaging
            • 3396
            The primary is not causing that problem. You can try however. The cleaning blade was issued to most dealerships because they found that certain issues like this one was cause by the blade. What's the meter count on this device?
            • A\ztech
              • Feb 2011
              • 57
              The machine has 375k I am going to order both. blade and coronas just to cover my bases, customers being a pain
              • vigour
                • Aug 2010
                • 1038
                I had 3 calls on Tuesday--all solved with wires.
                It is very difficult to tell if it is wires or blade, every time I swear it is the blade it turns out to be wires.
                Some run for hundred of thousands no problem, others need wires before 100k.
                The filter is usually full of fluff, and the housing smeared with dust.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Its a Process of elimination. Also cost effectiveness.
                  Advance my ass!
                  Piece of shit machines.
