paper jam ir 3045
  • bm1
    • Apr 2013
    • 21
    #16
    Re: paper jam ir 3045
    hi.....thank u for all replies..
    Yestedey i try to change...
    before
    cassete 1 is using paper A4, cassette2 using A4R, caseette 3 is use Folio and Cassette4 using A3...
    cassete 1 is always jamming if i use A4 like the picture ....no matter how much u want to make copies..it's always jam
    After
    Cassette1 is using A4R, cassette2 using A3,casette3 still F4(folio) and cassette4 is using A4...the problem solved...i make 20 copier or more and u know what..there is no jamming paper at all ....i try for 1st side copy only..
    • redzventures
      Service Tech
      • May 2009
      • 45
      #17
      Just to throw a slightly different angle on the problem and possible solutions. According to our friend it only jams on A4. We need to find out if it jams on A4 from all A4 cassettes or just one. How does it feed A3. If it feeds A3 OK then the fuser may well be fine. Of course, the simplest and most obvious would quite rightly be the setting of the blue dial in the paper cassette in question. If it is set to A4R then it could jam exactly where it has according to the illustration. I'm thinking its something silly like this if it's only on A4.
      Can you tell us if it works on A3?
      Sorry, just read that problem solved although it doesn't sound like it will stay solved.
      • bm1
        • Apr 2013
        • 21
        #18
        Yes...your right ..I had try for cassette2 for A4...and still jam...but I haven't try for A3 on cassette2...tomorrow I'll try it and give u the report....
        • Peter Sim
          • Sep 2008
          • 445
          #19
          Originally posted by bm1
          dear tech team...i have problem with ir 3045 ...the paper always jam if i use A4....can anybody help me[ATTACH=CONFIG]20550[/ATTACH]
          How about you copying single sheet of a4 paper,did it jam at the same place (at fuser unit)?
          Did you recently change fixing film?
          • bm1
            • Apr 2013
            • 21
            #20
            yes...the fixing film is new...ithink the problem is from the separation roller...because when i using A4 from cassette 4 there is no problem at all... only the different that i can see is cassette 4 is already use pre registration flag that covered with plate..cassette 1 no plate cover....
            • Peter Sim
              • Sep 2008
              • 445
              #21
              Just wanted to know,
              Did you change only film or the whole fixing unit?
              what are the grease that you apply?
              When you manually turn the fixing unit is it hard to turn or is very soft?
              Casette 3,4 just give you a guide line to trace your jam problem
              Do you know how to check your jams code?
              *28* > Display > Jam
              May be from the jam code ,you will find out which sensor level that cause you the jam problem
              • bm1
                • Apr 2013
                • 21
                #22
                yes...i'd check the histry jam... ps13 and ps10...
                • Peter Sim
                  • Sep 2008
                  • 445
                  #23
                  may be try to interchange the fuser unit with good one.....to confirm
