IPF8300 2F42 Nozzle Check Error
  • nykr95
    • Feb 2013
    • 37
    Hi! I finally got my printer almost working. I can now print but have problems with the B line not printing on 1 color on each head left and right. I know that this can be caused by the Flex cable. What I was wondering is why is it on both heads. Seems like if it was the cable it would be one head or the other. It is the last block on the nozzle check on both the left and right. It is not the entire color only one line. Any ideas?
  • onlyinnewfoundland
    • Apr 2013
    • 235
    Re: IPF8300 2F42 Nozzle Check Error
    Can you post a nozzle1 pattern from service mode?
    • JustManuals
      • Jan 2006
      • 9919
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • nykr95
        • Feb 2013
        • 37
        Here it is it: IPF_Nozzle.JPG
          • Apr 2013
          • 235
          We recently had an 8100 (pretty much the same machine) stop printing blue after replacing a print head. Turned out to be a seal in the bottom of the entire ink tank unit. Unfortunately we had to replace the entire tank unit because the seal was ridiculous to try and replace.
          If you have a manual or know how to remove covers from this, you can probably swing away the tank unit and make sure you don't have any air in the lines. That will totally screw these machines up. Sometimes the ink line may be just a little loose, and sometimes sucks air.
          Not sure if the blue is causing this, but it looks like you have a left head issue - there is a break in one of the cyan blocks.
          • nykr95
            • Feb 2013
            • 37
            I'm not convinced that's the issue. If you notice I am totally missing two blocks - one from each head. The missing spots on the cyan are only because I don't want to do another head cleaning until I resolve the missing blocks. If I run a cleaning it will use up a lot of ink because it doesn't see those two blocks. The manual says it's most likely a cable or electrical - but I thought it was unusual since its on both heads - which means two different cables.
            • nykr95
              • Feb 2013
              • 37
              Hi - Anyone else offer any help on this. I basically gave up on this project 6 months ago and just came back to it.
              Regards
              Steve
                • Apr 2013
                • 235
                Hey man
                Just to chime in again - I recently had a client with an 8300 and one of the grids in the nozzle simply vanished...not even a bit of ink. I ended up changing the main controller and the problem went away. I also ended up installing new heads too because they were just so bad by the time the client got around to calling us about it.
                Anyway - yeah...main controller..and then it worked right away.
                If you get a new controller make sure you use the L-Printer tool from Canon and update the firmware before you install new heads, I think the boards are still on older firmware if you buy them new...but I could be wrong. You can force the machine into download mode with by holding stop + navigate when you power on. Just hook up USB and you should be good to go if you have that little program and the FW file handy.
                Cheers
                • nykr95
                  • Feb 2013
                  • 37
                  Newfoundland:
                  How likely is it that it's the Main Controller Board? If that's it then I have basically changed all the boards but the power supply on this machine.
                  Anyone else have experience with this 2F42 error?
                  I have made contact with a Senior Sales Rep at Canon who I met at CES who has promised to help me out at the get the printer working Any other thoughts would be nice.
                  Regards,
                  Steve
                    • Apr 2013
                    • 235
                    What have you changed so far...I need to see a complete list.
                    • nykr95
                      • Feb 2013
                      • 37
                      I have changed the Carriage PCB, Head PCB, Flexible Cable Assembley, reseated all cables several times, 1 new right head.
                      Regards,
                      Steve
                      • silviu_25
                        • Jan 2019
                        • 27
                        Regards,
                        Steve
                        Hi, I know it passed few years from them but do you remember how you solved your problem?
                        I have the same situation unfortunately.
                          • 22804
                          what have you done to it?
                          5 years you can pretty well assume he: 1) didn't get it fixed 2) didn't report back ( pretty common with noobs )
                          what have you done?
                          is it the EXACT same machine?
                          exact same problem?
                          have you tried the suggested fixes?
                          • silviu_25
                            • Jan 2019
                            • 27
                            what have you done?
                            exact same problem?
                            Thank you for reply,
                            I have same Ipf8300, and what I've done so far Is: because I had 2f48 error I changed carriage relay pcb, multisensor, head management sensor and reference plate. I bought 2 used prinheads witch I tested on owner printer and nozzle check was perfect. Now ( after a month of sitting on my desk) I installed printheads and after ~20 mins of replenishing with ink I get 2f42 and asks me to turn off the printer, so I can not print anything in normal mode.
                            In service mode I can print a nozzle check and is missing one block on R printhead ( see attached photo).
                            I rechecked and cleaned with alcohol all the flat cables from carriage relay pcb, I cleaned with alcohol the printhead pins and carriage pins, I didn't checked flat cable on mainboard but for sure I'll do that tomorrow.
                            I don't know what to do, change the mainboard or the printhead. Some people telling to change mainboard, carriage and printheads but to be honest I'm trying to fix this printer from January and I'm tired and out of money so I'm looking for ways to be sure what to change once and forever.
                            • silviu_25
                              • Jan 2019
                              • 27
                              I've found this document http://www.copytechnet.com/forums/at...rvice-part-pdf
                              and I'm wondering if those cap absorbers can be the cause of my missing block.
                              I'm so confused...
